Looks like you got the better model than mine...
Is that your project? Why didn't you flush the port too?Other things you can do that do not take much time are to flush mount the sub like in the first pic by adding a square baffle behind the sub cutout. Also you can get a router with a bit that will make all edges rounded which is nice and can also improve air flow a bit on the port.
those are some things i will have to try. but i dont have a good router yet:crap:Other things you can do that do not take much time are to flush mount the sub like in the first pic by adding a square baffle behind the sub cutout. Also you can get a router with a bit that will make all edges rounded which is nice and can also improve air flow a bit on the port.
thank youLooks great, clean and simple, I like it.
You said you are happy with the output....anything you can compare it to? I have been eyeing the buy 1, get 1 sale...
yea i was kinda woried about that when i put the top peice on since it was cut weird. is that the only place you're talking about or do mean all of the screws?Looks great! The only thing I would recommend would be to not put screws so close to the end of the wood. Even if you pre-drill, it's still very easy to split the wood that close to the edge.
Thanks for the input, sounds like a bada$s little sub //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifthank youumm its as loud if not louder then two 12" rockford p2's in a small sealed box and soulds far better. and its getting half the power they were. as show on this page, http://www.caraudio.com/forum/showthread.php?t=182978&page=2, but of course that didnt last for long since that box i built really made them come alive. other then that there isnt a whole lot i can compare it to. i can tell you that the sq is great and in a small car they have the potential to very very loud for what they are and with little power. hoped that helped
All the screws I can see are pretty close to the edge of the wood. I try to keep them about 4-5 inches away from the edge of the wood. Even with pre-drilling very deep, I was splitting the wood with 1.25" screws at about 2.5" away from the edge of the wood.yea i was kinda woried about that when i put the top peice on since it was cut weird. is that the only place you're talking about or do mean all of the screws?
thanks![]()
