Build Log- Infinity Kappa Perfect 10- 1.5@35hz *PICCSSS*
mikey060
as the title states this box is 1.5cf tuned to 35 hz. im not done it yet but here is where i am at now. it will be going in a 97 saturn SC2 and powered by a mtx 2 channel getting about 300 watts. now onto the pics:)
alll the wood cut on my new table saw:yumyum:
back and sides glued and put in place.
front on
more pics to come
more pics...
yea i am aware the top is off a bit(left of port) but it will be sanded tommarow. reason for it is the sheet of mdf wasnt straight and threw the cut off.
took the car for a drive and took it to its owner. he was very pleased, as was it. the ouput, as bassmekanik mentioned, is very impressive off of 200 watts give or take. the customer was very pleased and i will be finishing the install tommarow with an amp rack to clean all the wires up and make it look pretty:) like always, all comments/suggestions are welcomed and appreciated.
You do nice work //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thanks pv, i was hoping you would chime in:) . as you can see, i took your advice you gave me a while back, about keeping a wet rag to wipe up the excess exterior glue:naughty:
if anyone is curious, heres the saw i used to make the cuts. first time using it and i think it went pretty well. make most of the cuts like a hot knife on butter
mikey060
mikey060
Calgary, AB
uhoh45
