Buck's Exploder build log
DC can make 270a alts for most vehicles on the standard bracket. Alternatively, get a dual bracket and run both the HO and the stock. Stock takes care of your vehicle's electrical and possibly front stage, then your sub amps get the full 270a
Not going with DC, and can't run dual alts on this without spending a ton of money. Dual alts is very difficult on my vehicle.
My electrical does just fine
I like overkill.
EA quoted me a max of 220a on my pathfinder, unless they can do more on your exploder. DC IMO is the best option if you don't want to spend extra $$$ on a custom bracket
This is what I've done today so far.
//content.invisioncic.com/y282845/emoticons/boobiez.gif.bcca53c4e1c9539300cad4d7d1b9dd4d.gif:boobiez://content.invisioncic.com/y282845/emoticons/boobiez.gif.bcca53c4e1c9539300cad4d7d1b9dd4d.gif:boobiez://content.invisioncic.com/y282845/emoticons/boobiez.gif.bcca53c4e1c9539300cad4d7d1b9dd4d.gif
Ok, as you see it here, there are 4 sections. The 2 sections closest have 25 square feet of Audio Technix deadner. The closest one has 2 layers, the furthest has 3 layers. I did that because I don't want to pull the headliner off again, so I did it right. No questions about it now.
The 3rd section away, has 5 'runs' of .5 MDF between each of the cross braces. There is still more bracing to be added to that.
The first section, where the sunroof is, there is MDF all the way around the sunroof (almost done) and the sunroof is sealed shut. Not sure if I will add anything else to that part yet.
---------- Post added at 07:01 PM ---------- Previous post was at 07:01 PM ----------
The AT deadner is 80 mil.
Buck
little alien on campus
Buck
Inside of a pyramid
mobeious
BP1Fanatic
BP1Fanatic
