hispls
I've run my JBL/Crown 6K into a 3" 4 layer coil sub. It doesn't make that sub handle 6000W+ it means I know what I'm doing and regardless of what number is printed on the amp I'm not giving the sub more power than the coil can handle faster than it can shed the heat.people throw 1500 watts with a clean unclipped signal on one of them just fine demoiing the whole day, this is pure clipping. Get off that stupid argument lmao. His electrical couldnt hang when he's not driving plain and simple and it lead to clipping. Even if he had 500 watts on them, it would die slower but it'll still generate a lot of heat compared to clean power. You are literally telling everyone to use a smaller amp in every fking thread rather than addressing the real issues which the OP already stated.
The math is very clear on this. The difference in power averaged over time of a square wave is @ 40% more than a sine wave of the same amplitude peak to peak. Now that's assuming OP can't tell the difference between a hard square wave and sinusoidal wave, in which case do you think he'll fare better with a larger amp? From there any partially clipped waveform is some percentage less than 40% of the power over time of a pretty waveform.
The shape of the waveform is almost completely irrelevant, the only thing that matters is the flow of current over time.
Also I did not tell OP to use a smaller amp, I told him he is burning coils because he is giving them more power than they can handle which is 100% accurate. He can learn to go easy on the volume knob, buy a smaller amp, or buy more robust woofers or add another coil to better manage heat, or even buy a pre-amp with a compressor.
Your going into this with the assumption that a 2.5" coil can safely handle 1500W (or whatever your buddy has printed on his amp) and any evidence to the contrary you're going to move the goalposts, play "no true Scotsman" and perform various mental gymnastics to discard the fact it the evidence contradicts your theory.
