Box size check please.
  • 5
riddla
nf
Im just modelling a potential box. 46in long x 18in high by 15in deep.
using torres box calculator im getting a net volume of 4.05 ft with a frequency of 29.53hz.
port area is 57.75in .
port width 3.5in
port length 36in
My question is would one 15in subwoofer be ok in this.
sub response is 19hz-1.2khz
power is 1200w 600rms
xmax 14mm
vas 4.58 cuft
fs 25.3
QTS 0.437
QMS 4.68
QES0.482
Im hoping for a low tuning.
Any advice welcome.
Ive had these for years. got like 6 of them but always building different boxes.
This is the last box Im going to build
does it have double baffle? if so i got less than both of u 3.79cf ad (subtracted .15 for sub disp) so 3.94 just box (i subtracted the port boards too)
Sorry 4 late reply. No. It doesn't have double baffle. I might put another board on top though.
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
I would like to a bandpass box wherein the subs are facing each other and each have their own sealed enclosure with the center section being the...
407
riddla
riddla
nf
riddla
    May 12, 2024
Brendon Jenness
    May 11, 2024
