Box size check please.
  • 5
riddla
nf
Im just modelling a potential box. 46in long x 18in high by 15in deep.
using torres box calculator im getting a net volume of 4.05 ft with a frequency of 29.53hz.
port area is 57.75in .
port width 3.5in
port length 36in
My question is would one 15in subwoofer be ok in this.
sub response is 19hz-1.2khz
power is 1200w 600rms
xmax 14mm
vas 4.58 cuft
fs 25.3
QTS 0.437
QMS 4.68
QES0.482
Im hoping for a low tuning.
Any advice welcome.
Ive had these for years. got like 6 of them but always building different boxes.
This is the last box Im going to build
does it have double baffle? if so i got less than both of u 3.79cf ad (subtracted .15 for sub disp) so 3.94 just box (i subtracted the port boards too)
Sorry 4 late reply. No. It doesn't have double baffle. I might put another board on top though.
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
5K
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
I would like to a bandpass box wherein the subs are facing each other and each have their own sealed enclosure with the center section being the...
riddla
riddla
nf
riddla
