Box for ssa evil 18... help
MmatsDude
Hey guys this set up is going in a Lincoln town car trunk.
I could do
30 width
20 depth
22 height
Gives me around 6 cubes gross. After sub and port it would be around 4.8-5 cubes net
Are this box dimensions ok for this sub?
Not competing. Will be a musical daily set up.
Go with the absolute biggest box you can stuff in there while still leaving room for the port to breathe. The backseats don't fold down in that car and I don't think they even came with a ski pass thru so it will be hard to get a desirable amount of bass in the cabin.
Can always build your own port from a sonotube..that’s why I prefer slots and can get the port more precise
sonos are still 10 and 8, there is no 9, which looks ideal for his setup vs the other two.
Slot is a complete waste of airspace in comparison and no where near as efficient which is out of the question when OP has next to no airspace. SSA subs need airspace, my Zcon 12 didnt come alive until 3.25 cubes.
Actually if you go into a building supply store you'll notice many tubes nested inside each other. Actual inner diameter of them varies a bit. You could very probably go into your local big box home improvement store and find one with exactly 9" inner diameter if you cared. At this point OP really only has the airspace for a 15 and anything he does will not function very well.
MmatsDude
MmatsDude
Los Angeles CA
MmatsDude
