Box Question
3 parts combined,
i guess u have to sacrifice your some more of your trunk if u really want it to be 6 cuft. cause thats my best , with port displacement it will be -6 cuft //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
good luck
i guess a could go a lil under 6 cubes.(Very to close 6 though) i really dont want to go pass 20 inches depth.
on the first diagram, Letter "D" is the 17" from the hump to the top or from the bottom to the top?
what are the disadvantage of using 1/2 or 5/8 wood...?
maybe i could double up or use 3/4 on the part the sub is being mounted.
17" from the bottom //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
and about wood thikness am not sure , i always use 1 inch,
but 3/4 is great.
17" from the bottom //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifand about wood thikness am not sure , i always use 1 inch,
but 3/4 is great.
did u calculate using 1inch or 3/4
what was the depth? 17 or 20?
the depth is 21" //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif (i guess 1" is not that pain in the @$$) or what u think? am just tryin to give u max internal vol. u can get. and hey if u didnt buy that 15" y dont u just get a 12" because of ur tiny space (just a comment)
hey man cant u c how many attachment up there and the back page , check on them ,
and i didnt calculate internal vol yet. so i didnt consider if it is 1" or 3/4"
u tell me what we will use , i will do the calcu. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
heh.. i didnt notice the attachments yet. thanks bro.
3/4 inch im prolly gonna use.
im thinking having the sub fire towards the rear and part of the box plexi (showing the back part of the sub)
now the porting ... how do i port this ?
am goin to sleep , i will figure that out while sleeping , will reply u back after 12+ hours //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
u try to figure out a way also, we share idea's //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
am goin to sleep , i will figure that out while sleeping , will reply u back after 12+ hours //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifu try to figure out a way also, we share idea's //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
will do... if i slanted the back... could i push the front in a bit? or would that change things again?
yup u can slant the back , for now am tryin to figure out a way to build the port with the least vol.
and yet not an external port.
What are the effects of having dual port opposed to having 1?
more SPL less SQ? Do you think this setup is overkill?
as far as i know, when calculating port tunning, vol , lenght and area * two ports,
it will be the same,
but one thing, remember that two slot ports will take more from your enclosure volume. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
i think im gonna be ok with 1...
do u think 6 cubes is over kill for this setup?
maybe i should go with something smaller?
plazman
plazman
USA
plazman
Doxquzme
    Jun 20, 2026
Doxquzme
    Jun 20, 2026
