Box question
  • 3
Depending on where you are and how serious you are about the sound. Many places carry plexiglass in very thin pieces and even small pieces. If you are looking into a larger area for the plexi tho you will want to go with a thicker and better grade of plexi or even step it up to Lexan. These can normally be purchased at a plastics or glass company. Most major cities have at least one! Check the phone book for either of the two and call around and get ur best pricing.
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
Yeah I'm in a circle right now too. I'm going to use 3/4" birch so I don't want to build it twice, stuff ain't cheap.
5
Emphasis added. The answer is, because you can also see DCR at other frequencies and because low impedance is extremely torturous on...
9
Common chambered sealed or ported is fine. Just make sure you have sufficient bracing
I played with the current setup I have and it's a sub port same side box. Seemed cleaner up but hit way harder faced back. I didn't know how much...
4
Switcharoo
Switcharoo
Michigan
ss3079
winkychevelle
    May 24, 2024
