help real quick
  • 2
hillzz22
I'm trying to help a friend of mine with a complet install. Put in new head unit, RF punch 400 series amp, RF 12's. Anyways, got the head unit in fine and hooked up everything, wiring the subs in parallel because the amp is 2 ohm stable. The head unit works perfectly but for some reason the amp just won't turn on. We've tried everything with the ground, and i suspect thats it. If it isn't the ground, it must be the remote turn on. What is the best wire to connect the remote lead to coming out of the back of the HU? Is muting or dimmer wire a good choice, or should we try something else?
Thanks,
Aaron
As a quick test........check the fuse on the main power comming from the battery to ensure it was not blown or overlooked and not put in place once install was complete. Check to make sure you have voltage to the amp. Put the multimeter on your ground point and other lead on your + on the amp and you should see the voltage. Then you can verify the remote lead is bad or not functioning properly by taking a short wire (temporarily) and touching it over to the + on the amp. If the amp cuts on it is not getting the signal from the head unit.
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
215
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
629
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
404
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
378
hillzz22
hillzz22
Willington, CT
Alaxan
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
