Box Help *15" L7*
i heard for it too sound good it need to be around 5Cu and tuned to 33Hz, correct me if im wrong.And i could use chicken wire at the port and use poly-fill to make the tone deeper.
#1. don't use poly because you have no clue what it is for(obvious)
#2. don't put anything over the port.
volume sounds about right but will depend on power and vehicle
whats it going in ? what power ?
those specs might have worked for some ppl but you may need a diff set up /lots of variables but that a good starting point
pm me for a design quote
#1. don't use poly because you have no clue what it is for(obvious)#2. don't put anything over the port.
well i was checking out the box hints on kicker and they said you could loosely fill the port area with hardware cloth and chicken wire and loosely fit poly--fill in it do get lower bass response, yell at kicker not me //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
volume sounds about right but will depend on power and vehicle whats it going in ? what power ?
i decided to get an american bassASA1000D.1, FI BL12, and knu konceptz wiring //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
nah kicker recommends it for their ported boxes too....makes it sound smoother in a way, Ive used it on a 15" L7 before in 4.5 cubes tuned to 33. Sounded pretty good
De_Troit!
De_Troit!
Canton Twp. MI
l7runner
