Box for (4) 1508's
gross volume : 4.41ft^3
- port volume: 1.41ft^3
-sub displacement: .3ft^3
2.7ft^3
With a 11.25" x 6" port, you have a tuning right around 40hz, according to the carstereo.com calc.
gross volume : 4.41ft^3- port volume: 1.41ft^3
2.7ft^3
Thats how much the port volume is? Man, i was thinking it was a lot less for some reason.
I'll bump up the height 1 inch, that should put me over 3 cubes.
**** im ****n up today! //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif ok so if you raise the box height to 16.75 that would be nice!
check out the screen shot
edit:
sry its tiny! so basically with the same size port just the box 1" taller you achieve 3.354 ft^3 before sub displacement and a 36.9hz tuning.
the port would be 33.5 long like your original.
you should keep them in about .5-.6ft each after disp
also tune 38-42 with them. you will be happier if you do it now rather than rebuild later.
you should keep them in about .5-.6ft each after dispalso tune 38-42 with them. you will be happier if you do it now rather than rebuild later.
So my box should only be 2.0-2.5 cubes net? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
bunkerking09
Current Status: Win
bunkerking09
Kansas City, MO
bunkerking09
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
