*Box design w/ pics...*
  • 5
Rawr-DQ
!!!!Vote Third Party!!!!
Okay, I used bassbox pro 6, and doing my best to fit a 6 cube box into a small a** trunk, this is what I came up with:
The subwoofers (4)
Driver Properties
Type: Standard one-way driver
Company: Alpine
Comment: Type-R series
No. of Drivers = 4
Mounting = Standard
Wiring = Parallel
Dual voice coils = parallel
Fs = 28 Hz
Qms = 8.31
Vas = 58 liters
Xmax = 13.87 mm
Sd = 467.6 sq.cm
Qes = 0.45
Re = 1.8 ohms
Le = 0.67 mH
Z = 2 ohms
Pe = 300 watts
The Box:
Box Properties
Type: Vented Box
Shape: Prism, square
Vb = 5.954 cu.ft
Fb = 28 Hz
QL = 6.536
F3 = 31.82 Hz
Fill = none
No. of Vents = 1
Vent shape = rectangle
Vent ends = one flush
Hv = 24.5 in
Wv = 1.825 in
Lv = 24.5 in
The design:
I would show you the graphs the program produced, but it is too much of a hassle, anyways there you have it! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Well, I looked into mounting the vent elsewhere, and came up with this:
old:
Hv = 24.5 in
Wv = 1.825 in
Lv = 24.5 in
@28Hz
F3 = 31.82 Hz
new:
Hv = 5.25 in
Wv = 5.25 in
Lv = 10.25 in
@29.14Hz
F3 = 31.49 Hz
The vent will be mounted facing the same direction of all the drivers (unlike last time where it was mounted on the side) in the top right-hand corner in the picture.
I still think you should make the port a lot bigger especially if your using all 4 subs. the width 5.5" is alright but id go with a higher port also.
547
857
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
750
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
Rawr-DQ
Rawr-DQ
Fort Myers, FL Posts:____________31,337,666,999
Rawr-DQ
SPLBassJunkie
    May 21, 2024
    May 20, 2024
