Box Build for vetkilr
Actually it was and I quote:
"I actually have a better option yet
I have used threaded wood inserts in the builds that involve interchangeable ports. Its basically a "nut" in a way, that screws into the wood. Inside it has threads to accept a bolt. Works very very well, and would probably be your best option.
B.J."
This was in reference to how Birch grabs better and is stronger to hold subs.
J
When I said this, I was referring to the way the two seperate enclosures will be mounted together. I was recommending the inserts over having you just screw them together. There is no way I can drill and install them for the woofers and be able to guarantee they will fit/line up correctly. Know what I mean?
BTW, they were scheduled to be picked up by DHL this morning. Ill have some tracking info for you tonight.
The tricky bit is that they're soft and floppy and they may be stretched a tad to go over the frames. I've used them in the past and come out...
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
Thanks everyone for the feedback. I got scared of the 4th being to much for a newbie but did end up building a box to 2.1 Cubic Foot tuned to...
Love this sub, hate AB's site, short on info for sure. American Bass XR-10D2 box recomend: If you want to tune a 2.75 Cu Ft box (for two of these...
bjfish11
FisherCustoms.com
bjfish11
Garden Plain, KS
vetkilr
    May 20, 2024
    May 20, 2024
