Bought set of tweeters, very quiet sound... are they blown/broken?
ckunke002
I bought a set of Pioneer tweeters, 30 bucks for a pair, and they have rave reviews everywhere I've looked. I have coaxial speakers in each of my doors and then a sub, but at head level there are several places in the car that the highs are very low and drowned out by road noise and mids/bass.
I bought these tweeters to put more at head level on the door panels for each door. They are rated to handle 40 watts RMS but I don't have an amp to power them so I was going to run them off the head unit which can put out around 25.
Since I don't yet have time to install them into the door panels, I decided I just wanted to test em out and see how they sound. I unplugged the front door speakers from my 4x50 watt amp and hooked up the tweeters to it. At first I couldn't tell if they speaker wire wasn't connected to the output terminals properly because I couldn't even hear the tweeters over the rear coaxial speakers (which were still plugged in). I ended up unplugging all of the door speakers and turned up my system nearly all the way to just see if they would get loud. Nope... not at all. With my 500 watt sub and my door speakers, I can't imagine i'll hear these things at ALL. Which doesn't make a lot of sense, because my coaxials are sharing 50 watts between a mid bass driver and a tweeter, whereas these tweeters get the whole channel to themselves.
I was under the impression from reviews that the tweeters would scream, and really fill in the sound void. This is pretty underwhelming lol
Here they are: Pioneer TS-T110 (tst110) 7/8" Hard Dome Tweeters
Anyone know what the deal might be? I know I can return them but I want to know if this is the way it's supposed to be or not.
Side note... only a pretty small amount of wire is coming out of the jacket on the stock speaker wire for these things... Could that possibly (probably unlikely) be the problem, that I need to expose more of the wire?
Not sure why you aren't getting enough sound. One problem might be that your head unit does not put out 25 watts per channel. Probably more like 10 RMS.
I'm not sure why you aren't getting any output.... But there are a lot of misconceptions and misunderstandings in your post. Too many to really point out for ya. If you wish to continue learning and growing in this hobby, I HIGHLY recommend you read around a lot more before you make another purchase. And read and reference this site, it has a TON of knowledge: Basic Car Audio Electronics
That being said. I have on theory. You're getting minimal noise when just the tweeter is connected. And you're getting no high-end when the coaxial is connected. It sounds to me like you have a High-Pass filter set on your amp, and it's cutting off the high-frequencies. I'd suggesting turning the crossovers to off, or full, or pass-through, or whatever option it is, and see if that changes the sound for ya.
If you wouldn't mind, try to point out a couple misconceptions that you think I have. I've been working on my stereo for years and feel like I know a fair amount of what's going on.
My amp is always set to all pass, I deal with HP and LP filters on my headunit. The tweeters I bought have an in-line crossover so I understood that should take care of the crossover issue, although not as effectively as an external crossover would. My headunit has my speakers hi-passed at 100 hz, but even still with the inline crossover that seems to be mostly irrelevant.
Yes the tweeters were new, the crossover point is 7k and it's an inline crossover that came with the tweeters.
Thanks for the website Underfighter.. lot of good info in here. Been reading for about an hour.
Maybe I was just expecting something different, I don't really know. I don't have much experience with tweeters I was just expecting more sound. Maybe it's a lower freq range that I'm missing...
Any other thoughts guys?
Yes the tweeters were new, the crossover point is 7kand it's an inline crossover that came with the tweeters.Thanks for the website Underfighter.. lot of good info in here. Been reading for about an hour.
That crossover point does seem quite high. Unless it's a REALLY gentle slope, but that would still be less than ideal. Most people really don't need more than two tweeters in their entire car. I would try either adding more power to the front coax's, and if that doesn't work, switch to a component set.
Yea...but you should be able to hear them pretty good on 50x2....I'm running 2-8 ohm (really 5 dc ohm) Dynaudio tweeters on an Audison 60 x2 and they get loud.
The slope is 6 db/octave. This might sound dumb but, a component speaker set is simply a set of mid-bass speakers and tweeters... how would that solve my treble problem? Just because components are often higher quality than coaxials? Because I already have the tweeters... Just more details would help
Because more "treble" comes from the mids than you think, that's why I brought it up. Honestly, they should get kinda loud on fifty watts each. Try another source of power. If they still don't have much sound, return/exchange them.
Any suggested brands for a good component set? Could it maybe be that my 4 channel full range amp simply doesn't cover >7k very well?
you've never heard just tweeters playing and expected more, happens all the time. People seem to have no idea how little sound comes out of just tweeters.....And I run a ton of supertweeters and by themselves it's still not very loud.
Play them WITH the coax's and you should notice a diff up top, but if you need more overall volume then get better speakers/more power...
Your one stop shop for hair care and mobile electronics? Who could ask for more?
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
4K
Damn this is comical. Finally got a hold of someone there via phone and they are not taking RMA's right now,lol. The switchover to the new system...
33
7K
ckunke002
ckunke002
Portland, OR
mlstrass
    May 31, 2024
    May 24, 2024
