Bassman999
BASS OBSESSION
my new amp Autotek MM4000.1 will benefit from one too, at that price I am going to buy one too.
X2.... Lmao the strut tower not a bad idea, sounds like a bit of work. I have a Expedition mines is grounded on the bolts to my back seats which are bolted to the frame. Some say its not a good idea, but i sanded it and its all metal to metal i have no issues.just get that line driver i recommended. It will make you lower the gain down and improve sound quality at the same time
Should be fine as long as you cannot measure any voltage drop.X2.... Lmao the strut tower not a bad idea, sounds like a bit of work. I have a Expedition mines is grounded on the bolts to my back seats which are bolted to the frame. Some say its not a good idea, but i sanded it and its all metal to metal i have no issues.
is it common to have one of thease things when having a big amplifier ? or is my gain settings where they are at now going to be ok when the box gets ported and everything, i have a feeling it will but i am going to get one of thease things regardless.my new amp Autotek MM4000.1 will benefit from one too, at that price I am going to buy one too.
I dont know if they will actually build him a new box or just modify the one he has.Ports/subs facing up in a trunk usually sounds like a$$, and has lots of cancellation. It may work, but it would be a rare case. Subs up/ports back or to the side works best in trunks, the best would be subs /ports rear or firing into the car, but I'm not sure of your trunk heigth and depth. Just my 2cents
Are you saying a positive and a negative are connected together on the subs? If they are I don't know how you're ending up with a 1 ohm load. When checking with your dmm are you checking the load for each sub or both together?The wiring on the subwoofers does not look like that diagram at all, it is wired up completely differantly each subwoofer has its own speaker-cable, and they go to the channels on the amp -- ++ and each speaker cable is bridged from a + to a - then goes to the woofer, connects to the - + then 2 small cables go around back and connect to the other connection points, the other subwoofer is setup the same.
each subwoofer indivudually, because i placed it on one positive terminal and one negative terminal as i was instructed.Are you saying a positive and a negative are connected together on the subs? If they are I don't know how you're ending up with a 1 ohm load. When checking with your dmm are you checking the load for each sub or both together?
They are going to re-do the hole trunk to make the box work, i said to them use the fibreglass if you can because i would prefer to keep the box fibreglass as it can be more moldable to my trunk and utilize more space, so the subwoofers facing outwards horizontally and a big *** port on 1 side of them correct ?I dont know if they will actually build him a new box or just modify the one he has.
Now if he can get a (new) box, then I say subs and port back. and bigger than the box is now would be preferable if space allows. I doubt you can get more volume than the box is now though as the box is utilizing the spare tire area as well now.
Maybe amp and batt in spare tire area to make more room for a bigger box?
well a member in this post said DO NOT port them upwards as it will act like a sealed enclosure is this correct?Ports/subs facing up in a trunk usually sounds like a$$, and has lots of cancellation. It may work, but it would be a rare case. Subs up/ports back or to the side works best in trunks, the best would be subs /ports rear or firing into the car, but I'm not sure of your trunk heigth and depth. Just my 2cents
How can you tell that they are out of phase and mis-wired ?Out of phase, mis-wired in terms of impedance andfinally last but not least sealed RE SX 18's cannot sound good.
