Just built my box and I put a couple bolts into it for the + and - wires. Anyway I put a washer on each side to get more contact with the ring terminal and when I drilled the holes I didn't think about the size of the washer. So the washers on each bolt are like 1 cm apart from touching. Is this OK? As long as they never touch (which is kinda impossible since they're locked down tight) I should be ok right?
