Big 3 upgrade worth it by itself?
LaserRed38
Bay Area, CA
I used to have my MRV in there now and an MRD-M1001 with 2 10" Rs. Sold the Rs and MRD and now I only have what's in my sig. I had always planned on doing the Big 3 and a battery ugrade as I also have my bi-xenon HIDs hooked up to the stock battery. I'm going to be upgrading to the stuff in my sig pretty soon here...My question is, upgrading the Big 3, is it worth it by itself with those amps and my HIDs hooked up to the stock battery? Or should I just use the 4ga I have in there now and get a dist block, then run 8ga to the two amps and leave everything else alone? I am usually one for overkill, so my gut is telling me do the 0/1 Big 3, then have 2 ga coming from the battery (and I would get a Yellow top or something similar) to a dist block, then 4 ga to the amps. Obviously that would be best, but would it be needed with just a 4.100 and a 1.600? Also, is the Big 3 upgrade only worth it if the battery and alt are upgraded? I can probably squeeze the Big 3 and battery in, but it wouldn't be for a couple months after I got the equipment. Should I just wait and do it all at once? Sorry for so many questions...//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i hate reading gobs of sentences like that...so what exactly are you asking... if you should do your big 3 upgrade along with a new run to the rear amp?
I plan on doing the Big 3 eventually. I'm asking if it is worth it to do it first, before any other electrical upgrades, or should I do the Big 3 WITH a new/better battery? I probably won't have enough $ or time to do the equipment AND Big 3 upgrades, but even when I had my old amp and sub in the car, I never really had significant voltage drops...
Personally I'd say upgrade it...You'd be amazed at how much it actually helps...Your voltage would prob sit higher and current flow would be much better...personally I'd also run a + and - run to the back...it really helps A LOT how far away are you from Fresno?
always do the big 3 first. it provides better current flow and keeps your electrical sustained at a set voltage alot better then the speaker wire that originally came on the car. you may never even need a better alt. but go big 3 first, and see how it effects you and then battery, and then alt as last resort. but having a bigger alt without the big 3 done is pointless. you want more current flow to keep your voltage steady. bigger wire will do that.
im now running a HO 180a alt with big 3 upgrade and I can say it was the best thing I have done for my system(running a 3000watt system). My headlights dont dim anymore nor does my dome light:D
deffinitely worth the extra couple hundred bucks imo..
Take this for what it's worth.
I'm running on the stock 90A alt in my Passat, and a factory sized battery (autozone replacement). I'm also using more amps than you and they also draw more current, I've got 0awg running from the battery back to my trunk. The ONLY upgrade I did was for the battery ground, because I had extra 0awg after I ran the power wire, and my lights do not dim at all, even at full tilt.
It's actually kinda sad, but if I pull the switch to roll up all 4 windows, the lights dim more doing that than they do with my stereo running full volume.
I'd keep the stock battery and alt, use 0awg for power wire and ground. If you have dimming issues after that, then you can tackle the big three, but my guess is that you could probably get by without it.
Thanks for the input guys...My car actually came stock with 4 ga, but I'm planning to eventually do exactly what I said. I guess I'll just do the Big 3 first and keep my 4ga power/ground cables in there for now and use a dist block with 8 ga coming off of it to the amps. Upgrade to 2 ga/4ga later.
And to kurt, I'm actually going to school in Stockton, so I'm not too far from Fresno...
^^ Agreed. And costs can be reduced by using welding wire, you don't have to buy a BIG3 kit from monster (just an exaggeration) for 200 dollars, it can all be done with local bought wire.
2012 Civic Si, and yes 4awg, didn’t see a need to go 0/1 since I’m only installing the mono D amp the subs, anything further would require...
901
Ok I didn't really think it mattered because ground is ground just wanted to be. Sure. So I'll do alt to bat, batt ground to alternator mount, and...
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
606
LaserRed38
LaserRed38
Bay Area, CA
Tehgregzor
    Apr 28, 2024
    Apr 28, 2024
