LaserRed38
I used to have my MRV in there now and an MRD-M1001 with 2 10" Rs. Sold the Rs and MRD and now I only have what's in my sig. I had always planned on doing the Big 3 and a battery ugrade as I also have my bi-xenon HIDs hooked up to the stock battery. I'm going to be upgrading to the stuff in my sig pretty soon here...My question is, upgrading the Big 3, is it worth it by itself with those amps and my HIDs hooked up to the stock battery? Or should I just use the 4ga I have in there now and get a dist block, then run 8ga to the two amps and leave everything else alone? I am usually one for overkill, so my gut is telling me do the 0/1 Big 3, then have 2 ga coming from the battery (and I would get a Yellow top or something similar) to a dist block, then 4 ga to the amps. Obviously that would be best, but would it be needed with just a 4.100 and a 1.600? Also, is the Big 3 upgrade only worth it if the battery and alt are upgraded? I can probably squeeze the Big 3 and battery in, but it wouldn't be for a couple months after I got the equipment. Should I just wait and do it all at once? Sorry for so many questions...//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
