Big 3 upgrade on magnum
  • 5
Haha I might have to try that. I'm waiting on all my Knukonceptz wire to come in, wouldn't mind using it all up.
I have 2 runs pos / 2 neg. Voltage drops at lowest to 13.3-13.4 while driving with stock alt but 4 batteries. I still did the same thing in my F150 with 2 batteries and stock and it still worked well.
That's really good considering what you're running, plus you have your stock alternator still in. I might get another battery if I get too much voltage drop. I'm going to be running between 1.5-1.7k RMS, I just can't decide on a subwoofer and amplifier.
I failed to mention my stock alts charges at about 13.8v while driving, so I'm not dropping that far.
But regardless of how much power you are running (if it's big enough to require 4 gauge or larger wire), IMO you should run separate ground/power wires from the front battery.
2012 Civic Si, and yes 4awg, didn’t see a need to go 0/1 since I’m only installing the mono D amp the subs, anything further would require...
933
Ok I didn't really think it mattered because ground is ground just wanted to be. Sure. So I'll do alt to bat, batt ground to alternator mount, and...
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
RT_MAG
RT_MAG
MICHIGAN
RT_MAG
    May 16, 2024
    May 16, 2024
