Big 3 upgrade - how should I fuse
  • 6
Goldtaz1
I am going to be doing the big 3 wiring upgrade in the not so distant future and I would like someone to help me understand the concept of fusing. I have read things that suggest that your fuse should be just large enough to support the total load your amplifiers are capable of pulling, but I have also read material that states that fusing is meant to protect the wiring that you use. I have purchased a 300 amp fuse for the wire that will run from my alternator to the battery positive, is this incorrect?? Please help. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
no fuse needed. your alt. will only send as much power to the battery as needed. whatever fuse you have running from the battery to the amp its what you want. you will be fine with no fuse.
1. fuses protect wire
2. they protect electrical equipment (an amp for instance)
3. they protect you...
if you wanted to be the safest mofo on the block, every circuit in the car's electrical system
should be fused...
however, if I were you, I'd fuse that alternator wire. I've got 1/0 for that wire fused with a 250A fuse. With such a thick wire, if for instance that unfused wire were to get cut and shorted out in an accident...well, it's a done deal...
no fuse needed. your alt. (as long as it's working correctly) will only send as much power to the battery as needed. whatever fuse you have running from the battery to the amp its what you want. you willprobably be okay, but it's still a good idea
edit for quotes
yeah...fuse that wire...
in the event of a short, your alternator is safe, but now your battery is looking at a dead short to ground. Major bad news if that's an unfused wire.
I appreciate all of your responses. I have completed 2 out of the three wires and I have already seen a difference in my charging voltage. The third wire (alternator positive to battery positive) is going to take a little time because I have a Mazda Protege' 5 and the **** alternator is under the engine down by the front left wheel of the car. Who in the hell thinks of doing that kind of crap? At any rate it will be done. One thing I will tell you is that I was completely floored by how poorly the original ground was done by the automaker. The old ground was not metal to metal in the sense that they had not scratched the paint off. In my experiences I have always been told that the best ground comes from a good metal to metal connection, meaning scrape the freakin paint off!! I guess the automaker doesn't take into account people like all of us putting in crazy systems that crave tons of power. Peace. //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
The battery ground is one of the simplest upgrades you can do to the charging system...amazing how some people neglect that.
And I share your pain about the alternator //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Ford, in their infinite wisdom, shoved the alternator underneath the air intake...so I have to take off the intake just to get to the alternator connection. That's something about a van that *****...short hoods = no room to work on things. I have to change the spark plugs from inside the cab! :/
2012 Civic Si, and yes 4awg, didn’t see a need to go 0/1 since I’m only installing the mono D amp the subs, anything further would require...
964
Ok I didn't really think it mattered because ground is ground just wanted to be. Sure. So I'll do alt to bat, batt ground to alternator mount, and...
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
Goldtaz1
Goldtaz1
Montgomery, AL
JimJ
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
