Papermaker85
Banned
Its all in the dampening you choose.I was about to say I could fit a 12 GCON ported, but then I looked at the recommended specs. GCON's while in the same wattage range as the SA 12, require so much more box. I'm guessing this is a SQ thing.
People often overlooked higher QES Subs(including me) thinking a large enclosure is required. In reality it's just natural for them to be put into a larger enclosure because the driver is nautrally more efficiency below and above FS. where there is less actual resonance on one particular frequency. Another words the curve or the Q at resonance is wider.
The only real downfall there is a loss of efficiency and higher power compression but what the 3-inch coil that won't be an issue..
