Beefy 10" recommendations
I use Winisd as well. I'll plug those in after dinner and see what I come up with. How much power?
Sent from my SM-N920V using Tapatalk
Using a hifonics colossus at 4 ohms...will be 2200 watts once I get my new battery and singer alternator (both on their way).
Also, no worries if you use WinISD as well. I will certainly toy with it this week in preparation for this weekends box building adventure part 2.
Alright. I'll holler later.
1. Size: 8”
2. Cutout Diameter: 7.28” / 185 mm
3. Overall diameter: 8.7”
4. Nominal impedance: 4Ω
5. Power handling: 800W (rms), 1600W (max)
6. Voice coil diameter: 2.5” / 63.5 mm
7. Displacement: 0.08 ft3
8. Fs: 41.458 Hz
9. Qts: 0.439
10. Qes: 0.477
11. Qms: 5.601
12. Vas: 7.431 liters
13. SPL: 82.30 dB (@ 1w/1m)
14. Magnet weight: 160 oz
15. Speaker connector: 8 AWG
16. Re: 3.2Ω
17. Sd: 201.60 cm2
18. Xmax: 18 mm
19. Mounting depth: 6.57” / 167 mm
20. Shipping weight: 26.72 lbs (12.12 Kg)
21. Sealed box volume: 0.3 ft3
22. Ported box volume: 0.5 -0.75 ft3
Even more info...if you have the time. Like I said, no worries if you are busy with other things!
1. Size: 8”
8. Fs: 41.458 Hz
9. Qts: 0.439
10. Qes: 0.477
11. Qms: 5.601
16. Re: 3.2Ω
17. Sd: 201.60 cm2
18. Xmax: 18 mm
blockquote><p>%5Bimg%5D<a%20href=
https://uploads.tapatalk-cdn.com/20170221/b8eb9198e5301955b83f18897b199901.jpg' alt='b8eb9198e5301955b83f18897b199901.jpg'&gt;
Interesting, I'll play with WinISD as well and see what I get. I appreciate your help!!
Id do 1.25 tuned to 35.. just me though. Larger box will peak more around resident frequency.
Thanks, I'll play with WinISD this week to figure something out!! I appreciate your input!
Yeah check it out. The t/s listed aren't complete so I just allowed winisd to fill in the blanks. At 1.25 @35hz it modeled up very peaky.
Sent from my SCH-I605 using Tapatalk
I had a look at it in depth
Its def a small box woofer. .8 is much more ideal but i feel lowend will suffer drastically. With the mms fs and rms i wouldnt tune much lower than about 34..
Also i always fill out the compensation for coil temp. I normally use 300 degrees as an average
I had a look at it in depthIts def a small box woofer. .8 is much more ideal but i feel lowend will suffer drastically. With the mms fs and rms i wouldnt tune much lower than about 34..
Thank you! I have not had a chance yet to mess with WinISD...but if it is truly a small box woofer, maybe I have jacked something up. I will look into it again when I get home. It just seems like there should be SOME bass with the subs, not zero bass...even with such a small box.
So after got home for work, I decided to give the sub woofers one last look before building a whole new box. What I had discovered upon pulling the subs out, is that one of the speaker wires got pinched off due to so little clearance. If you notice from my pictures, I doubled the baffle, and I believe the speaker wires hit that since the sub is so stout! What I had to do when putting the subs back into the enclosure this time is get the wires as flat as possible against the subwoofer so they wouldn't get pinched off.
I'm happy to say that this set up is amazing, and works great!! I'm definitely happy with these subs and how well they perform in such a small enclosure.
Never said they were. Commentary was more to being able to purchase one or the other or 40% off and take a 90 day warranty... which I would in a...
861
Doors and dash? Year, make and model of the car? Amplification? Midranges or coaxials? Need some more specifics about what if anything is already...
574
Heck...done right...you could get an amazing sounding stereo using $15-25 drivers from partsexpress 😂
956
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
I read your post and thought about all the aftermarket decks that were installed using the factory power wire. This is why manufacturers quit...
92
6K
Boomintempo
<---Old tempo setup, lol
Boomintempo
Washington
Boomintempo
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
