battery lug size question
Jimg
CarAudio.com Regular
just wanted to confirm before I order them from ebay
on the battery lug size if I am using 2/0 welding cable is the conversion size the size of the lugs I need to order are 1/0 for car audio
or do I just order the welding cable lugs from Temco welding supply? they are a little higher price but not by much
Lugs should match the cable. 2/0 and 1/0 should match. If you're using welding wire then pick up welding wire lugs:
Thanks for the help
Getting ready to start putting everything together. I am sure I will have a lot questions
Jimg
Jimg
Jimg
