i borrowed a schumacher battery charger that can can do
10 or 20 amp fast charge
2 amp slow charge
75 amp engine start.
it says its compatible with agm batteries.
can i charge my kinetik battery under the hood even though its wired parallel to the back batteries? (4 batts in total)
and it says on the manual that i must connect positive to positive post and negative to the vehicles ground. the cable is too short for it to reach the frame. can't i just connect it to the negative terminal?
my negative terminal is grounded to the frame of the vehicle with 0 gauge wire.
thanks for the help!
2 amp slow charge
