Bama's build
Got 4 runs ran, 2+ and 2-, @hertzmafia you weren't joking that grommet is large, also layed carpet out to hopefully get shaped to flooring.
Sent from my SM-G935V using Tapatalk
[quote name='bamaman']Got 4 runs ran, 2+ and 2-, @hertzmafia you weren't joking that grommet is large, also layed carpet out to hopefully get shaped to flooring.
Sent from my SM-G935V using Tapatalk[/QUOTE]I like the green chair [emoji23][emoji23] you should keep it as a passenger chair for demoing
Sent from my Moto G4 using Tapatalk
Took half a day off work to get front seats from junk yard, they are in pretty decent shape but not bad at $100 for the pair.
I was able to get them and the center console installed , still have to trim to fit and put panels on but I'm able to drive it now. I want to drive it a little before I buy a alternator.
Took half a day off work to get front seats from junk yard, they are in pretty decent shape but not bad at $100 for the pair.I was able to get them and the center console installed , still have to trim to fit and put panels on but I'm able to drive it now. I want to drive it a little before I buy a alternator.
i'm liking it..
I still need to pick which subs to run, I have no idea and needing help, I heard 4 skar zvx 15's and liked them, the brutal sounds big brute 15's look nice, I thought about a bunch of 12's but I don't know but I need to get it together because it's almost time to start building a shell
4 18's of your pick and amp each sub or double up on 2 Brazilian amps.
Will leave you space to put batterys and amp behind the wall and really seal off good.
Best format ive seen unless you wanna do a 4th or 6th order.
Sent from my Moto G (4) using Tapatalk
Yeah I was thinking 4th or 6th an 2 Brazilian's
8 12's or 6 15's in a 6th would be nice, but you will need some power for that lol
I was thinking 2 Tara 8k's, 6 15's might be over budget but I was originally thinking 8 sa 12's which would be in my range
6 15's of fu 750 15's would be under your budget.
bamaman
bamaman
Phenix City, AL
bamaman
vegang
vegang
