b-pillar build, what would to use?
BassAndBeer
WOOD* what type of wood should I use and how many sides of the box should I double baffle? I will be using threaded rod for bracing. I went with a flat wall, slot ported tuned to 28hz, 43 cubes. this is my first wall. i will be glassing the inside of the box and adding 45 angles on each corner. plenty and plenty of bracing, as 18s will shred any box up without improper bracing
Birch wood. Double or triple wall all the way around and 3-5 layers on baffle. And is that 43cubes before of after displacement? Your going to be like just free airing the subs. 43cubes is huge.
43 before displacements, 32 cubes net. so 11 ply birch, 3/4 or 1 inch?
BassAndBeer
BassAndBeer
California
hispls
