I don't have a ton of experience with this kind of stuff but I had a simalar problem with a different program. One fix was the unit of measure was incorrect and the other wanted to auto fill some of the information but I changed it.
Yeah, if bassbox pro is anything like winisd, then it will complain if you overwrite parameters that it can figure out. Some parameters can be calculated if you know some other existing params, so that's what it's most likely doing. If you overwrite the ones it fills in, it gets confused because stuff no longer matches up.
These are the parameters that came or pre loaded in the database. I didn't overwrite any of them. It's possible that they were preloaded incorrectly to begin with. I have winisd but I haven't tried it with this driver yet.
It just looks as though bbp thinks one or more of these are incorrect. So I don't know if this is a software issue or an issue with the way the t/s parameters were measured.
Maybe @denim can help, at least to verify the t/s parameters and their respective units.
