AutoZone battery vs car audio battery???
What vehicle? And what year? For 3k RMS, 270a alternator(DC power or mechman), and 2 batteries(I got xs power d3400 and d3100) and having my amp wired down to 0.7ohm from a crescendo bc3500, my voltage starts from 14.7, and drops down to 14.1-14.3. Keep in mind I got a 270a alt and just a single run of 1/0 to the back batteey
Between your amp's max draw and your car you can see over 300a load on your battery at peak. That's not all the time, but that's the peak.
You will want a 270a alternator for sure considering that you will . If you don't want to go with an AGM battery you will need to double up on the flooded batteries, so it won't be that much savings overall going with the flooded.
I like my Optima Yellow Top
Some people have good luck with the optimas and others dont...personally I know quite a handful of people who have gone through multiple yellow tops right after the other. If they aren't resting high 24/7 they will die very quickly. As well as the fact that you can get a better battery for the same price, especially if you buy a used battery from say RAM_Designs on here.
IMO the yellow top isn't worth it, mine didn't last the winter, still havn't had any problems with my agms.
have you called mechman to see if he could make the 270 ho alt?
---------- Post added at 02:52 AM ---------- Previous post was at 02:51 AM ----------
which one idles at a higher amp rate.
Be careful of IDLE ratings, we don't rate idle because in various circumstances, vehicle conditions, system loads and along with other factors, the vehicle idle speed can vary. The difference of 50rpm can cause the alternator to fall below it's turn-on speed.
globalminds_ent
globalminds_ent
oxford ms
MECHMAN
