alright based on what you gave, according to RE you're at 8.545 cubes tuned to 33hz without sub displacement. I am using my calculator for this and am coming up with 9.597 cubes tuned to ~37hz before sub displacement. don't know what the deal is with the net displacement but as stated the tuning frequency is off by a few.
check the math for the box he stated it's not 9.597 cuft more like 8.92cuft this is with port displacement and the point 42 will be made up with the subs displacement so the box volume is closer to 8.5 cuft
outside dimension 49x 25.5 x 18 minus 1.5 from all sides to get 47.5w x 16.5hx 24L. this is the inside dimension if using 3/4 inch stock
port 8.25w x16.5h x i used 21L inch long just a guesstimate before tuning 16.5x9.75x21 multiply those to gather then divided by 1728 to get 1.9555cuft minus this from the box of a 10.88cuft box yields 8.92 cuft you must be using the out side as the inside dimensions lmao.and it yielding a bigger box like 9.597
here is the math i use to figure ports just encase you want to check the other calculators out this one does not use t/s speaks to calculate box if this gives any one a hint
Ported boxes
Letters used in formulas as follows
Av or area of vent or Port area=pie time radius squared of a 3 inch port which =7 x1 or just 7 for this formula do not use round port of like 3 and 4 inch it will throw off formula use the pie time radius of port to get those by 1 inch
vb or volume of box =cubic inches for this formula has to be cubic inches can be gotten from width time height times length can divide this by 1728 to get cubic feet for manufacture specks
lv equal length of vent in inches
fb equals tuning frequency
We use the formula above like so we do this first and write it down av(1.84time ten to the eight power )then hit equals and write it down
Next we take vb(lv+.823squae root of av ) take those to answers after written down and divide by each other and add it in the square root of this part like so .159 square root of answer = tuning frequency
General rules to ported boxes
The port must not be a ratio greater then a 9:1 area
Must not use more then plus or minus 20%of manufacture specks for their boxes of what they perform best in.
The port must be measure down the center line and a correction factor of .5 time h must be added in the h is from hxwxL of a port
fomula for area lxhxw/1728
