I can tell you, but it doesn't matter what Aq box you put in that calculator. It will be off by 6-7hz. AQ says to multiply your cubic feet of what you want the box to be by 16, and that gives you the port area. Go to the calculator and you'll see. 8.5cu ft. x 16 = 136sq port area. Put these numbers in from top to bottom in the red fields.
49
18
25.5
25.5
0.75
8.25
You'll end up with 8.5cu ft. and 136 of port area. The calculator will give you all the dimensions at the bottom. Can you find my mistake?
Yeah, but are AQ subs supposed to be tuned that low? I thought they needed higher tuning?There is no mistake the calc is wrong but not as much as you think. From my calculations I came up with 8.82ft^3 @ 32.5 Hz before sub displacement.
because when Greg did the Calculator he adjusted the parameters to accomadate an RE sub not an AQ sub or any other sub. call and ask him yourself.I fail to see how the calculator can tell the difference between a re sub and a different manufactures sub.
No need to call! I believe you that's why I'll just do it like Dj said.because when Greg did the Calculator he adjusted the parameters to accomadate an RE sub not an AQ sub or any other sub. call and ask him yourself.
alright based on what you gave, according to RE you're at 8.545 cubes tuned to 33hz without sub displacement. I am using my calculator for this and am coming up with 9.597 cubes tuned to ~37hz before sub displacement. don't know what the deal is with the net displacement but as stated the tuning frequency is off by a few.I can tell you, but it doesn't matter what Aq box you put in that calculator. It will be off by 6-7hz. AQ says to multiply your cubic feet of what you want the box to be by 16, and that gives you the port area. Go to the calculator and you'll see. 8.5cu ft. x 16 = 136sq port area. Put these numbers in from top to bottom in the red fields.
49
18
25.5
25.5
0.75
8.25
of course he'll say that, why would he want you to use his calculator for other subs. Ive seen the same flash based calculator on other sites and it still had the same problems. He did nothing to the program.because when Greg did the Calculator he adjusted the parameters to accomadate an RE sub not an AQ sub or any other sub. call and ask him yourself.
Better recalculate that.alright based on what you gave, according to RE you're at 8.545 cubes tuned to 33hz without sub displacement. I am using my calculator for this and am coming up with 9.597 cubes tuned to ~37hz before sub displacement. don't know what the deal is with the net displacement but as stated the tuning frequency is off by a few.
sure, why don't you do so as well b/c the box before any displacements is 10.89 cubes and the port displacement is ~1.6 cubes.Better recalculate that.
did you even do the math? doesnt sound like it or else you need learn basic math your self. I'm not doubting it is wrong.you dont have tocalculate for where the port is just the port itself. posistion is pretty irrelevant.
bromo learn math or gtfo i do boxes for a living as well as alot of other shit and re calc is wrong period.
