Audiocontrol Three.2 or Arc audio XEQ?
  • 4
What makes you think you need an eq? Eq's shouldn't be used to boost frequencies but more to cut unless you're lacking in some frequencies and need to boost them. What equipment are you running? Perhaps that money can be used to upgrade some of your equipment
Alpine 149BT
JL HD900.5
2 set of JL C5 comps
Gladen SQX12 Seal
Your DSP options for $200-$300 are a cheap used JBL MS-8, which does not require a laptop, a MiniDSP with add-ons, or Precision Power DSP-88R. The latter 2 options should also be paired with an RTA setup. You can get REW and spend roughly $100 to turn your laptop into a powerful RTA setup. Whichever way you go you need to do some research into how to tune, because without knowledge none of this is going to make your system sound better.
I can get the Helix around $600 and be done with it, thanks bro.
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
751
Good thing its under warranty and that you have contacted A.Control about the issue so it has been documented. It will help speed up the return...
Looks like half a dozen other makes/models on the market, rebranded . The shallow mounts look like they’re made by Pioneer but what the hay, one...
Go to DIYMA some people there are willing to remote tune it for you for a small fee. Usually around 30-50 dollars.
technobass
technobass
Clearwater, FL
trumpet
Decebal
    Jun 10, 2024
