AQ power handling question
I'm pretty sure that should be no problem. I killed mine but not due to factory fault. I believe mine died because of too little glue on the spider landing. They didn't like my 5k at .25.
Before I killed them they were bangin! LMAO
**** man.
I was going to run mine at 2000rms but my amp blew //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
So now I'm going to be running mine at around 1400
I'm going to start off on 1500w from my 9.1.
ask mlstrass.
He says they will take a beating. Running them at 2000 watts should be fine if it's clean power!
Big 3 and extra battery or no?
i think strass has 4 saz1500's on 2 hdc's
i've got a bxi2006 on a single hdc12 at 1ohm, probably seeing aronud 1800w, its my daily setup, but at the same time rarely listen to it above 70% unless im messin with someone, but even when i've got it full tilt, takes it like a champ doesn't smell or heat up at all
That's for comp right? I couldn't believe that for daily.
Does anyone have an idea how much (the most) these comps can happily handle?
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
485
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
373
Buck
little alien on campus
Buck
Inside of a pyramid
MasterOfAllBass
    May 10, 2024
3toneEYZ
    May 10, 2024
