AQ power handling question
I'm pretty sure that should be no problem. I killed mine but not due to factory fault. I believe mine died because of too little glue on the spider landing. They didn't like my 5k at .25.
Before I killed them they were bangin! LMAO
I was going to run mine at 2000rms but my amp blew //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
So now I'm going to be running mine at around 1400
i think strass has 4 saz1500's on 2 hdc's
i've got a bxi2006 on a single hdc12 at 1ohm, probably seeing aronud 1800w, its my daily setup, but at the same time rarely listen to it above 70% unless im messin with someone, but even when i've got it full tilt, takes it like a champ doesn't smell or heat up at all
That's for comp right? I couldn't believe that for daily.
Buck
little alien on campus
Buck
Inside of a pyramid
MasterOfAllBass
