Anyone fancy helping me - Hertz ML2500 10"
The sealed ML2500 way back in an FG box in my A4 Avant
True, the Hertz is a truly quality bit of kit. In the 0.5cu ft sealed box it really shone and kept my trunk space open for my bike and kids stuff.
However, being SVC 4ohm it was at its limit and my amps limit in the new car I have more space and I wanted to be able to get down to
It is for sale locally and at only £90 I have local Chavs wanting to give me £50 for it like the rest of the cheap crap on Craigslist
Box is out and under re-construction.
With the internal port out the volume is back up to about 34 L (1.2 cuft)
Got a new 4 post terminal plate, flushed it into the side
Soldered on the '8ga' power wire on, it's the same thickness as the new 12ga speaker wire
Made the new external port, tune is about 35Hz
It is a little, Re spec is 1.5cuft net for the 'compact' design and I'm more like 1.2
I will run it for a while like this, will be wired to 1ohm so amp spec is 900rms, no idea if it will actually do close to that.
Will see how the SXX and the amp (KAC9104D) play together.
I may have access to a Massive Audio P1500.1D if I do get hold of it I will see how that sounds, if it seems worth it I may then build another box with Re's other recommend size 1.9cuft net
First 1/2 hour out in the car with no kids...
The box is much flatter through the lows now, it feels louder and the (admittedly poor) IPhone dB meter has it up from 122 to 124.3 on the same extended note in the same track as before.
The plot from the box calculator app is in agreement, getting the 3L back and tuning a bit lower flattens it out.
I have also wired each VC to the speaker outs on the amp as the diagram below, I'm not sure if it's now loading the amp to 2ohm or 1ohm?
Should I bridge +ve to +ve and -ve to -ve to make sure it's parallel and presenting a 1ohm load?
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
349
was never registered on the road so no, here in maine for a vehicle of that age all you need is a bill of sale. i still have original dealer...
530
LOL. Some of us have Issues that another can relate too. LOL 😂 😆
24
975
Are you planning on upgrading the alternator and add extra batteries?
762
Alex JB
Alex JB
Chicago IL
Alex JB
    May 16, 2024
    May 16, 2024
