another amp?
  • 2
billy2363
I know pretty much nothing about car stereos, i have 2 10 inch jbl power subs and an old jl audio amp. it says it puts out 4by 110. i have that bridged to my subs and its not hitting as hard as i want. Im wondering if theres anyway i could add another amp to my system or should i just buy a more powerful amp and lose the other one?
since your current amp is an older model you probably won't be able to find another one to match it. so i would suggest you get a more powerfull amp to power both of your subs and then you could use the jl 4x110 for the mids and highs.
what amp would you recomend getting in the 200-300 dollar range to power the two 10s? Or are there any other simple ways to incease the power or make it hit harder besides another amp? If i want the only bass to come out of my subs, not my rear and front speakers how could i do that?
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
521
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
Haven't 100% landed on which one, but I am down to those two
They managed to turn Covid into a wedge issue.
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
billy2363
billy2363
Grand Rapids
billy2363
    May 16, 2024
    May 16, 2024
