Amps are a ripoff?
one more thing about 1 ohm load, the current draw excides the 4 ohm by far...without a good electrical system all together its gonna cause problems...
although, if ure getting 2 kw rms,ure prolly gonna have to upgrade anyhow
does anyone know like what the exact difference is though in the number of ohms? and like as far as wiring would it be cheaper if i got a 2 channel amp and would that give me more power or what
i want the system for rap, plain and simple, i do listen to rock and everything basically, but if i change my music ill just turn down the subs or up depending, right?
by far eh? will of coarse its going to because its 4x as much power on a normal amp
on a regulated amp, like a jbl / jl which does the same power @ 4 and 1 ohm the difference is negligible
please stop posting your ignorance in this thread. you aren't helping
im building my own ported enclosure, i know that much, probs tune it anywhere rom 28-34 hertz, but yeah im just concerned about prices, i want to have the cleanest system around, im buying 4 new speakers and amping those as well, along with two 12's and a deck, and i want to spend like 1500-1700 max
What amp you choose has nothing to do with what music you listen to.
of course it does, why get a 2 kw amp if u dont need that much power? rap, r'n'b reagge etc. dont require the same substage as brian adams...im european, i guess we have different views on that
and jl is an exception not a rule...
why does his listening taste factor into what power he needs?
Rap gets 2kw amps, while rock gets 1kw amps?
You buy an amp to fit the subs, you buy the subwoofer to fit the listening tastes.
And You need to STFU so that the OP doesnt buy the wrong thing due to your piss poor advice
ban or die.....
slamnoma66
slamnoma66
mass
2Tone
Mike Mccabe
