Amp/ Sub Wiring
dannyz122001
ok... need a little help here. prob a simple answer but i dont wanna buy the wrong thing. looking to do 2 12'' solox off of 2 zx2500.1's. the mono's are rated at 2500watts at 2ohms. in order to wire the sub to 2ohms, i need dual 4ohm subs and wire them in parallel to get a 2ohm load correct? im still new to everything electrical so i need all the help i can get.
not sure if thats right or not... need advise
so dual 4's is correct? and im assuming that 2 kinetik 2400's and a 300A alty is enough charging power? and it is ok to do them at dual 4 in parallel on a 2500.1? thanks
as far as solo x's i would recomend dual 4's in paralelland not dual 1's due to the D1's being more like D1.4's ...
2 HC24000's and 300A alt will be plenty to power 2 ZX 2500's...
dannyz122001
dannyz122001
Baton Rouge,LA
jrobb
michigan born
    May 14, 2026
michigan born
    May 14, 2026
