wiring 6x9's to amp help
ok i just got my amp its a soundstream xta 360.2 which runs 2 channels at 90rms @ 4 ohms. i also have two infinity kappa 6x9's that are 2ohm speakers. i want to use the amp to power the speakers. now correct me if im wrong but in order for me to have the amp running at 4ohms i would have to series wire the speakers. this is what im kind of confused about because there is a + and - for each channel on the amp. im guessing what you do is
take the - from channel(1) of the amp to the - of speaker(1),
then run a wire from the + of speaker(1) to the - of speaker(2).
then run a wire from the + of speaker(2) to the + of channel(2) of the amp.
i hope this isnt too confusing but i have no pictures. also both speakers come with crossovers so i would be wiring the crossovers together right?
anyways please let me know if this is the right way to do it because i would hate to screw something up after spending the money on this stuff
thanks in advance!!
xdreamtheaterx
xdreamtheaterx
Cleveland, Ohio
xdreamtheaterx
michigan born
    May 14, 2026
michigan born
    May 14, 2026
