I need an amp to run one RE SE 12" sub. I'm not wanting to spend a lot more than 250. Here are the specs:
Electrical Q Value -Qes: 0.49
Mechanical Q Value -Qms: 4.5
Total Speaker Q Value -Qts: 0.44
Free Air Resonance -Fs: 25.1 Hz
Equivalent Compliance -Vas: 72.9 liters
One-Way, Linear Excursion -Xmax: 18 mm
Efficiency -SPL 1W/1m: 86.1 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 2.8 ohm
Nominal Impedance -Znom: Dual 4 ohm
Thermal Power Handling -Pe: 600 W
Force Factor -Bl: 17.7
i've seen a bunch of good reviews for the cadence TXA-1000D and its right around $199 on ebay //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif. Any other comments or suggestions are welcome
TIA
TIA
