Amp Recommendation for RE SE 12"
haul@ss
10
AK
I need an amp to run one RE SE 12" sub. I'm not wanting to spend a lot more than 250. Here are the specs:
Electrical Q Value -Qes: 0.49
Mechanical Q Value -Qms: 4.5
Total Speaker Q Value -Qts: 0.44
Free Air Resonance -Fs: 25.1 Hz
Equivalent Compliance -Vas: 72.9 liters
One-Way, Linear Excursion -Xmax: 18 mm
Efficiency -SPL 1W/1m: 86.1 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 2.8 ohm
Nominal Impedance -Znom: Dual 4 ohm
Thermal Power Handling -Pe: 600 W
Force Factor -Bl: 17.7
i've seen a bunch of good reviews for the cadence TXA-1000D and its right around $199 on ebay //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif. Any other comments or suggestions are welcome
TIA
I ran one 12" RE SE off a 2004 Rockford Fosgate T5002 Power Amp, running at 500Wx1 RMS at 2 Ohms. Got it on eBay, new for $350 in 2004.
Later, I ran it off the Infinity 611a Reference at ~720Wx1 RMS at 2 Ohms (per the birth sheet). Got the Infinity for $300 from Best Buy.
The box was per RE Audio's ported design on their website before US Amps redesigned it. I think it was 2.5-3 cubic feet and tuned to 32-34 Hz (I can't remember and I long ago dismantled the box).
I always got the feeling 3 cubic feet was too big. RE's website now says the optimal size for a ported box is 2 cubic feet.
BTW, the new RE wesbsite has a build-your-box calculator. You can tweak a box's dimensions and it'll tell you the net cubic feet and tuning you'll get. it's pretty cool.
http://www.reaudio.com/speaker_box/LPort_Box_Calc.html
Man I used this sub A LOT. I ran it in 2.25ft^3 tuned to 34hz and it rocked off many different amps:
Old school usa150
Rockford power 500d
Memphis 500d
JBL 600.1
kit audio 660.2
and a few more but anything with 500+ true watts will be great.
haul@ss
haul@ss
AK
Rich00
