Amp problem? Sub problem? I DON'T KNOW!!! Help!
Sorry. I am getting ALMOST no sound from the sub. What's coming through is the music. It's just very faint.
-I have tried adjusting the gain and have tried it with the low pass filter both on and off.
-I can hear the subwoofer from the driver's seat with the subwoofer controls on the head unit as loud as possible but what I hear then is a weak, lame sounding thump that was slightly out of phase with the rest of the music.
-The JL Audio website has a very specific blueprint with materials and dimensions for the box they recommend for this sub so I made it myself.
-If an additional amp is the answer, I will get one that will give it as close to 300w as possible.
-The sub is new.
Thanks. I really appreciate all this help.
dont go an crank your gain to max it will destroy your sub you could check out amazon an look for a amp that will do 250-300 rms at 4ohms (also when you get done go have your amp gains set properly 5-10$)
MRP-M500 - Alpine Monoblock
Power Acoustik GT1-1000
Sorry. I am getting ALMOST no sound from the sub. What's coming through is the music. It's just very faint. -I have tried adjusting the gain and have tried it with the low pass filter both on and off.
-The sub is new.
Music shouldn't be coming through the sub. You could possibly have the high pass filter on l ike mofoman suggested. Make sure your amplifier is set for low pass filter. Can you post the specs of your amp. I was having trouble finding that exact amplifier model when i googled it
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
727
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
717
If a sub's voicecoil fails, it will usually drop impedance causing too much current to go back to the amplifier. The amplifier then protects...
15
Have you checked the fuse block. With time, tight connections can loosen and cause failure. Refresh those contact points and test again. Remember...
254
nft987
nft987
New York, NY
seg_representin
    May 24, 2024
