Amp problem... phoenix gold mps2500???
lastcall
lastcall
This amp was recently just givin to me... i dont know too much about it except it was hardly used,its an older amp, and it pushed 2 jl audio15w4's when they cam out. i think this amp was released in 1994 or somewhere. my question....is this a good amp to power 2 JL Audio 10w3v1-d2s? if not let me know why or what to use.
Into 4 ohms @ 12.5/14.4 VDC
50/80 WRMS x 2
Into 2 ohms @ 14.4 VDC
125 WRMS x 2
Bridged into 2 ohm @ 14.4 VDC
510 WRMS x 1
Frequency Response
+/-1dB from 20Hz to 20kHz
Signal to Noise Ratio
>100dB
Input Sensitivity
200 millivolts to 2 volts
Input Impedance
>30k ohms
Input Voltage Range
10.5 volts to 15.0 volts
Typical current draw at idle
3 amps
Minimum Impedance MS series
2 ohm bridged/1ohm stereo
Minimum Impedance MPS series
1 ohm bridged/ .5 ohm stereo
Dimensions, MS250, MS275, MPS 2220, MPS2240
8.5"L x 11.4"W x 2.4"H
Dimensions, MS2125, MPS2500
17.0"L x 11.4 "W x 2.4"H
Dimensions, MS2250
25.5"L x 11.75"W x 3.35"H
Dimensions, MQ430
11.4"L x 11.0"W x 2.4"H
That is an awesome amp. Very good old school PG. I dont know the specs on those subs but I bet it would be a great match. On second thought..that amp sucks send it to me!!//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
If you want more info http://www.soundbuggy.com is the forum where all the people form the PG forum hang out...lots of good PG info from PG junkies
lastcall
lastcall
lastcall
League City, Tx
faulkton
