Need Amp Suggestions
MemphisSoul4U
The Black 'Hoe
I was just wondering if you all had any suggestions of amps i could run. Looking for 3 to 4kw. Multiple amps do not scare me (as a matter of fact, I kinda like the idea).
Some amps I was looking at were the:
MA Audio HK4000d
Clif Designs CDX-20A
Maybe 2 MTX Thunder 1501D
Some info on my setup:
1 RE Audio MT 10 with quad 2's
4.9 ft^3 ported box tuned to ~35Hz
Knukonceptz 1/0 wire
200 amp alternator
I will be installing two Optima Yellow Top batts soon.
How much are the RE 12.1's?
And what exactly is the power handling of a MT?
I know it will vary on enclosure, but a roundabout number will give me more of an idea, because I will be using this for dd with the sub volume on my eq turned down, but still want to pound at competitions...
At 2 ohms the MA would be perfect... at .5 you stand a good chance of blowing the sub... if the sub shorts the amp out you could loose the amp as well. If you dont have an amp yet pm me //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
MemphisSoul4U
The Black 'Hoe
MemphisSoul4U
Calhoun,TN
scottiej
