Amp clipping? please help me lol
Please stop. You have no idea what his input voltage is
i know but i'm just saying turn it down see if that helps.. when peps say it's not all the way up they normally mean 80% so almost 100.. but i think main problem is box and ss filter/ bass boost..
ooo i see a problem..
That bandwidth is way too large.
Do you know what your box is tuned at?
You'll want to set your LFP/HPF according to your box tune.
The LPF could be fine depending on what your box is tuned at, but that HPF should come down to at least 60hz IMO.
Didn't know that about ford radios, thats actually good to know.
Not sure how accurate that is. My ford’s max clean volume is 24 out of 30
I don't have a ford, just in case for later installs.
but this is also good to know //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
If they're 2.5 he can probably cook them.
https://www.sonicelectronix.com/item_17531_Power-Acoustik-MOFO-122X.html?utm_source=google&utm_medium=cpc&utm_campaign=Shopping-Campaign-General&gclid=CjwKCAjwssvPBRBBEiwASFoVd6F29WZo1nZkmugNlG3Qi5WF6Cr68w0Q-FQu_nlBD4N6LhX-lnKFhBoCjH0QAvD_BwE
If this is the same woofer then specs say 2.5
Don't even know if this is what OPs talking about //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
thats gotta be it only 1 i've seen and i looked at 500 subs under $200 this yr.. ppi has some that are basically same thing 1 has cool red basket but thats only pa mofo i know of..
You're right, and that's probably what OP has.
Would love to see pics of the subs in box as they sit in his vehicle.
Those PA subs are junk.
So....I've managed to **** off a few new members because I called their boss gear junk and haven't returned since. See if I can get another one.
I had my old mofo on my PRV at 4ohms for about a month. So about 2k give or take. Got a little smelly at first but gain down a smidge more and it stopped.
Sent from my SM-N950U using Tapatalk
Turn it down.
should have listened to you in the first place. credit goes to you. set gain back to 0 and then set slowly upped it. cant even get to 50% without it making the noise. adjusted to about 45% and set the other settings, and it sounds just as amazing without the noise. hats off to you. thank you. learned some more knowledge out of this. appreciate all the help
Okay thanks! That was the answer i was looking for. Btw what is the best audio format i should export/listen to? Im trying to rebass by my own so...
It's very likely this has to do with box rise and the fact that you should test for clipping along the entire frequency range that the sub plays...
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
bshultz0930
bshultz0930
Cleveland Ohio
Boomin_tahoe
