amp and sub compatiability
d4vew557
15
uk
ok. this is my problem.
i have a mrv t420 which is i have bridged i was planning on using it to run a 10" alpine type r but i'm not sure it will be powerful enough. i had planned on purchasing a dual 2ohm voice coil unit and wiring it so the amp see's a 4ohm load.
I think i may need to upgrade the amp in the future to a mono block but if i do i would be looking to run it at 2ohms but the the sub i was going to get won't be any good then as i would need a dual 4ohm unit.
is it possible to run only one voice coil that way i could get a 4ohm sub and use one coil for now then when i upgrade the amp i could rewire it for a 2ohm load.
d4vew557
d4vew557
uk
JimJ
vegang
vegang
