alternator question...
To find out the amperage draw on an amplifier takes its output power (RMS for average draw and total for max draw) and devide by 12. This will give a reading assuming the amp was 100% efficient. Now you have to consider that class AB amps are only about 60% efficient and class Dare about 80%. Divide the number of amps you got from the last equation by the efficiency of the amp and you should end up with a fairly accurate number.
so, amperage draw equation:
( output power / 12 ) / effeciency = amperage draw
example using a 1000 wattt class AB amplifier @ 60% efficiency
( 1000 / 12 ) / 60% = ( 83.333 ) / 60% = 138.9 Amps
Yes you are right. I wasn't thinking.
About 99.9999999999% of the charging systems out there are 14.4 volt
Just substitute 14.4 everywhere I said 12
( output power / 14.4 ) / effeciency = amperage draw
( 1000 / 14.4 ) / 60% = ( 69.444 ) / 60% = 115.74 Amps
Yeah that other number looked a little high. thanks Jmac.
I must have been thinking car=12Volt. Thats a common analogy and although not very accurate is what many people think.
It is the same one that Rockford Fosgate sells as well. They are identical and the NVX is cheaper as well. Even Amazon has them iirc for 199.99...
Okay cool bc I'm thinking about getting 5k amp and just wasn't sure if that battery would do but I appreciate all the help
18
I don't have one...but I check my voltage with a dmm once a week or so
944
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
Brock
SEXYTIME!! NIIICE!
Brock
KENTUCKY WHAT!!!
n2audio
    May 24, 2024
