After 6 months... Finished my first system.
K_Watson
It took 6 long months of adding a little bit at a time and learning as I went, but I've got it done. My first system is going to be finished tomorrow, I only have to build a bigger fuse holder bracket, secure the amp power wire in it's permanent routing, tuck some wires, reconnect the remote starter, and seal the slit in the firewall wiring harness boot.
Kenwood KDC-MP245 Headunit
4x Pioneer TS-G1643R 6 1/2" Speakers
Alpine MRP-M500 Class D Amplifier (500w RMS @ 2 ohm)
Twin 10" MTX Thunder 5000 Subs (250w RMS each)
34R Duralast Platinum AGM battery (Deka Intimidator 9A34R)
4 Gauge Power
4 gauge Big 3
Soldered terminals
PAC Bass knob
Sub cutoff switch
100% self installed //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Pics...
Big battery
Big 3 (The amp wire will be secured in the morning.)
Custom one-off billet aluminum fuse holder bracket //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Room to flex
Subs, amp, and if you look close, speakers!
More pics and a video tomorrow.
Fire extinguishers are ALWAYS a good idea lol you never know when you will need one.
And btw nice job on your first system...its refreshing to see someone that took their time to learn and do it the right way. Its a great start!
All finished... I made a new fuse holder, complete with brushed finish, routed and secured all the wires, and sealed the harness boot.
Wires routed and secured.
New redesigned custom one-off brushed billet aluminum fuse holder bracket v2.0 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Power and signal on opposite sides of car.
Headunit and Bass-knob
It's a Griffin AUX cable with built in microphone. I have an LG Optimus S Android phone and the last OS update killed the mic while a cable was plugged in, so I bought this one with a mic to fix the issue. Otherwise, while listening to my music I would have to unplug the cable to take the call which is not fun at highway speeds.
K_Watson
K_Watson
Indianapolis, IN
K_Watson
