Aero port help
one 6" = 28.26 sqare inches of port area
three 4" = 37.68 square inches (and they would each need to be 27.76" long)
All lengths are for flared ports, if using non flared then subtract one inch.
i have a box that is 2.5 cubes...what size port would i need to be tuned to 37??
ummm....will the port be external?
If not, you do know that the volume will change right? (which means the port length will have to change also to get the desired tuning)
BINGO
and 3 4" ports is way overkill
people keep forgetting that you only need 6-10" per cube with a round port......................
Are you going to do actual aeroports with flares on both ends? I’m running a single 4 inch aeroport on my little 750 watt 12. It has flares on...
And you failed to mention airspace of the box or the sub and power you were running. In 89 most subs were extremely low xmax meaning very little...
14
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
705
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
878
treylittlefield
treylittlefield
Sand Rock, AL
302yota
    May 18, 2024
    May 18, 2024
