Advice/Questions new system
Back to my original question, when I have 2 amps hooked up.. Should I get battery in trunk than? Or just upgrade the alternator instead of a new battery in trunk..Or just do big 3 and call it.
Do the big 3 and a single battery in the back won't hurt anything. No need to upgrade the alternator for that kind of power unless you have an old car with a very small alternator
---------- Post added at 11:55 PM ---------- Previous post was at 11:54 PM ----------
And the volt meter is a good idea. They're worth the $2 they cost on eBay
i would start with the batterynder the hood first .i wouldnt put a good batt in the back with a crappy one up front
Do the big three first. I have a Hifononics BRZ 1700 @2ohms and a 4 channel pioneer amp in a mini cooper with stock Battery and alternator only have 2 of the big 3 done grounds and am not having any problems with dimming at all. Im running 1 sd-2 10 soon to be 2 of them as soon as I finish my box
yea but hes already experiencing dimming issues.big 3 isnt a miracle fix. id say he needs at least a god batt under the hood if the stock one isnt new
I have a stock battery but I just put it in last year bought it from O rillys so it is relatively new.
Yes I was thinking of only doing 2 of the 3 because the 3rd one was confusing.. I can do ALT to batt easily and batt to ground easily.. But the other one about the motor is confusing so I might just go with the 2,
Stock is new, I replaced it thinking my old battery was dead. Come to fine out I needed a new alternator instead. My alternator is 6 months old.
I agree Im just waitig for my factory battery to die before replacing it. Now the way I was taught as Electrician when running Multiple batteries they need to be the same ones
---------- Post added at 01:29 AM ---------- Previous post was at 01:28 AM ----------
what type of vehicle is it?
the big 3 isnt confusing ur makin it harder than it has to be buddy..step 1 run fused power wire from alt to positive battery terminal..step 2 run ground from case bolt on alt to negative on battery ..step 3 run ground from the frame to the negative battery terminal...dont ground to block of engine
I have a stock battery but I just put it in last year bought it from O rillys so it is relatively new.Yes I was thinking of only doing 2 of the 3 because the 3rd one was confusing.. I can do ALT to batt easily and batt to ground easily.. But the other one about the motor is confusing so I might just go with the 2,
that is the easy one you ground your engine block AKA alternator ground to ground point. You should probably see a braided strap or something similar there now.
darron016
darron016
minneapolis, mn
NASTY08IMPALA
